Navy_Bob's avatar
Navy_Bob
Jayco Melbourne TV access
I have a 2014 Jayco Melbourne. The flat panel TV is above the cockpit. A lot of times the volume on the TV insufficient especially if the air conditioning is on. I am planning to install a sound bar above the TV.
Does anyone know how to get access to the rear of the TV so I can connect to the sound output?
Thanks
1 Reply
  • We have an 09.
    I had to remove the wood that surrounds the TV. It had 4 screws in it. Probably behind wood plugs. From there you will be able to access the TV. Mine was mounted on a metal bar that hung on another and was screwed to the plywood back. I took pictures as I went just in case. there are a lot of wires back there.
