Jayco vs Winnebago class A?
huntdooly
We are considering these two brands of mohos...in the short range, and wondered what people know about the differences in quality, ride, etc.
Thanks for your help!
20 REPLIES 20
garyemunson
As good as the Workhorse chassis were, they are getting pretty long in the tooth. The difference in availability of Ford parts vs WH will only widen. Although Workhorse still exists in name, they are not the same company, now only making some electric vehicles. This can make a difference if you need some brand specific part while on the road.
scbwr
Do some research on the Jayco motorhomes. One of their units in the 29' range received a lot of negative comments due to stability issues when on the road. In the same line, the 32' model seemed to be ok. Also, just do some general research regarding shorter wheelbase motorhomes being less stable, but it really varies by manufacturer.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
gafidler
If you buy a pre-owned Winne , you can get one with the GMC engine and workhorse chassie
jplante4
All other things being equal, choose the floor plan you like. I believe the relative quality between these 2 manufacturers is the same. Are you planning in going on the road? If which determine which had s the best service network. My guess on that would be the Winnie.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
azdryheat
They both use the same Ford chassis, same Ford V-10 engine, and same Ford Transmission.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Lwiddis
In the short range, I prefer Winnebago...long range too.
