Dakota98 wrote:
Mr.Mark wrote:
roadtriptoforever wrote:
I just bought my first motorhome. It's a class a. The guy I bought it from said he kept "killing the house batteries". He gave me a brand new set. But I want to avoid doing the same. I'll near power most of the time, so should I just have it plugged in all the time? Do I just charge it when they are dead or before going ona trip? Charge them whenever they are halfway dead? Nightly? Something else? These are sealed deep cells.
Thanks
Tell us what kind of motorhome it is and the type of battery charger, etc. Is it a diesel or gas?
MM.
What is being asked is: What type of "CONVERTER" do you have? That's the power control center of the coach. What is needed is the make & model number.
Exactly. Need to know what converter is involved here, and if it is one that has some kind of 'smart' charging or not.
Older converters are known to over-charge the batteries when left plugged in to shore power all the time. With a converter like that, you need to keep a very close eye on your batteries water levels, make sure they don't get 'cooked dry' from over-charging. I'm going to bet that may be how, why the previous owner wore out some batteries.
If you find that this is the case (and again, finding out what converter you have is the first step), then I would consider replacing the converter with a newer one that has 'smart' charging. Then, you can just leave the MH plugged in all the time and the battery charge will be maintained properly for you without you having to worry so much about it. You still need to keep an eye on the battery water levels, but you will not be adding water to them anywhere near as often.
A good example of converters that have this smart charging that I would highly recommend, would be
Progressive Dynamics 9200 series converters.
