leveler leaking
car54Don
2007 Itasca Sunrise 35A. Kwikee level best 3000 jacks. So the level 'best' may not be the best. The right front has been leaking from the top for quite awhile. Have to top up reservoir. Touch pad acts ups up from time to time. Have read a few different sites, some say can't repair, other site replaced while another opened up leveler, replaced 'rings etc' and welded back together.
any help would be appreciated.
thx
2 REPLIES 2
MrWizard
Moderator
Moderator
i had a leaky jack curbside rear
i added 'blue devil hydraulic sealer' to the jack reservoir
instructions say run equipment for 2 hours
i did not play with the jacks for 2 hours
i did take 10-15 minutes raising and lowering the rear jacks
to circulate fluid
we fulltime, in a few days the leaked stopped
occasionally if i fully extend/stress that jack, i will need to top off the fluid, sometimes i use pure tranny fluid , some times a 50/50 mix with blue devil, its a top up, so it doesn't affect the system percentage too much
blue devil says can be as much a 25% of fluid
a google search found it on amazon
beats buying a new jack
I can explain it to you.
1997 F53 Bounder 36s
1492
Moderator
Moderator
