valhalla360 wrote:
One thing to consider is the leveling systems I'm familiar with run 2 jacks at the same time (both front, both side or both rear). This causes the whole rig to rotate with the frame not twisting.
If you are doing it manually, one jack at a time, that can introduce a lot of twisting in the frame. Not a big deal for the frame as it's unlikely to fail but the house is bolted to the frame and not very strong...you might be opening up the seams in the roof as it all twists or loosening the screws holding the cabinets.
It is actually kind of amazing that RVs stay together at all when you consider they are twisting and flexing and turning and bouncing for 1000s and 1000s of miles as you drive down the road, over bumps and potholes, etc.
When leveling an RV, I believe you will either need to adjust 0, 1, 2, or 3 tires ("corners") to make them higher in order to get your RV level. I would contend that leveling your RV from a correct jack point (or like most people, just putting blocks under their tires) does absolutely zero damage and adds zero stress to the structural integrity of your RV.
In fact, it ALLEVIATES stress/twisting/etc. The fact that your RV is unlevel implies it is being stressed or twisted as long as it is unlevel. Here is an exaggerated example to illustrate my point... Imagine you pull into a campsite and your front 2 tires and your rear driver side tire are all perfectly level but your passenger side rear tire is 12 inches too low. You are parked there. The rear passenger side of your RV is causing your entire RV to be wildly unlevel. If you try walking in your RV it is sloping a tremendous amount. At that moment, the frame and everything attached to the frame is under much stress BECAUSE it is unlevel. It is designed to handle it, but it is under stress. If you now raise that passenger side rear corner (from a proper jack point and/or by putting something under that tire) you will NOT be stressing/twisting the frame but rather you will be
de-stressing/un-twisting the frame and putting the RV back to level (...I suppose you could call it the RV's happy place...being level). Right?
Or, another example...Assume you are parked perfectly level. I think we can all agree that when level and parked the RV and its frame and everything attached to it are in their happy place and they are not experiencing extra structural stress. Now imagine if you start putting blocks under just one tire (or jacking up just one corner from a proper jack location). You raise that tire/corner 3 inches, then 6 inches, then 9 inches, then 12 inches. As you are doing this, it is ADDING stress to the overall frame/structure/integrity of your RV. Right? Well, as you start removing this added height and you are dropping it back down to being level once again it is removing all that added stress. Making the RV level puts it in a state of the least amount of structural stress.
If the above is true, then any time you are leveling your RV, and you are doing so with items designed to support the load (either blocks under the tires, or jacks of any kind designed to hold the proper amount of weight) from a location designed for that purpose (ie. under the tire, or at a proper jack point), then you are actually REMOVING stress/twisting to the structural foundation of your RV.
-Chris
