farmingdad's avatar
farmingdad
Lights on sig
Headlights on 08 sig one is dim on drivers side , an when I dim them the other one gets dim an drivers side gets bright what could be wrong
  • I would run a temporary first to verify it is the problem.
    You should be able to test with Ohm meter. Test ground, it should be close to 0 Ohms.
    Test the voltage to ground with volt meter. Should be close to battery voltage, then start engine voltage should be close to alternator output voltage.
  • Can I run a ground wire from each headlight to frame will that ground it ,
  • wa8yxm's avatar
    wa8yxm
    First "Dim" and "Bright" are misleading.. Back in the 50's with what is called a "Single light" system (one sealed beam lamp on each side) the "Dim" was 56 watts and the Bright 36.. yup, got that backward.. That is why they went to HIGH and LOW beams.
    Today they tend to be all the same wattage.. But we need to know
    Is it truly DIM? (I had that problem) or is it high and low reversed?
    If it is high and low reversed I suspect you can figure out the cure Switch the wires) note: do a very good job of cutting and splicing, use MARINE grade heat shrink to seal the connection and solder please, at least 6 inches from the socket.
    If it is DIM... and a single lamp system. Well, as I said I had that problem. Finally fixed it
    My car has a "Single" system. on this type of system the the lamp has 3 terminals, HIGH/LOW and Common.. on mine the COMMON was bent, so it did not go in the socket,, Solution was to bend it back so it went into the socket.
    Now if you have a "Dual" headlight system (one on either side) then either one is HIGH and the other LOW, or.... One his HIGH/LOW and the other HIGH only.
    On this a bad ground will make a big difference.
    Finally. how to tell if it is HIGH/LOW swap
    You need a foggy day, OR a reflective wall or store front at night.
    The beams are clearly visible in the fog or the Bright spot on the wall (high or low) it will be obvious if lead swap is the issue.
  • Has it always been like this? Years ago, I had an auto that was wired incorrectly that caused this problem. A cut and splice operation on the wiring cured it.
    Fred
  • On many vehicles headlights are numbered for left side right side.
    Example 9007 goes on passenger side 9004 goes on drivers side.
    If you have 9007s on booth sides you will have one side bright beam and the other on low beam. When you switch from hi to low the lights will also reverse one side hi beam one side low beam.
