Wrong Lane wrote:
One limitation with a large gasser is buying fuel.
It is getting harder and harder to find locations where the pumps are parallel to the station. Now days many places have pumps that are perpendicular to the building and with the toad connected it can be a challenge. Even some of the large truck stops have difficult fueling lanes for a large Class A gasser with a toad.
Meanwhile my friends with DPs can use dedicated lanes with lots of room and fast fill pumps.
I do most of my camping within two days of home base and based on trial and error have discovered which stations are motorhome friendly and which to avoid.
Not a big deal but certainly a minor limitation of sorts
Safe Travels!
A large diesel coach has the exact same limitations except that it is actually worse. Sure the large truck stops have a diesel lane, if you happen to have a large truck stop along your path of travel. If not, you are in the same position as a gasser EXCEPT, not all gas stations have diesel. I've stopped at many small gas stations with a few pumps that I could easily get in to for gasoline that did not offer diesel fuel.
Since I travel a lot of the back roads of America, that was one of the reasons that I decided to replace my diesel coach with a gasser. In some areas out West, it may be 100 miles between gas stations so you can't be too picky.
