SPL TECH - You was talking about charging a battery not loading a battery...
You are way over my head with your thought process...
Try this yourself - apply 14.4VDC charging voltage to any deep cycle battery (even a hybrid deep cycle battery with cranks specs) and measure how many DC AMPS it demands from the charging source. You should find it at 17-20AMPS DC Current from the charging source. I have done this routine too numerous times to count when camping off the power grid with my 255AH battery bank... The only way to get my batteries to demand more DC Current is to increase the charging DC Voltage... If I increase the charging more than the 14.4VDC level I stand the risk of boiling out battery fluids over the charge time. I also stand the risk of overheating my battery case which may lead to other problems.
You certainly can load down a battery with some pretty high DC Current load for a short period of time... we are talking two different things here...
Your inline Battery cable protection can be valued at any number you want to put in there. Pick 30AMPS if you are only going to be charging ONE battery... In my case I would blow the 30AMP Fuse trying to charge my batteries. I have an 130AMP fuse between my battery bank and the converter/charger connection... Both the converter DC output and Battery Bank switch feed my 12VDC Distribution panel supplying all my 12VDC needs in my trailer setup...
If we are talking about two different things than just ignore all I said and maybe the better experts on here can help you here...
Discuss this point with some real experts please... I only know what to expect on my three 12VDC battery bank with the capacity of 255AHs... When my charger is applying 14.4VDC I see an initial current demand of 53AMPS when first hit with the 14.4VDC. Then this starts tapering back and in about 15-20 minutes will be down to around 8AMPS if the batteries are good. After two hours my smart mode charger then drops to 13.6VDC and the charge demand drops even lower for any additional hour. At the end of this three hour period the battery bank is at its 50% charge state...
Thats all I know with my setup...
Just saying
If you measure your DC output level on your truck alternator system you find these same basic levels being used... Must be for a reason perhaps...
I don't think I could demand an additional 53 AMPS DC current from my present Truck Alternator setup when it is already being demanded with 17-20AMPs from the truck Start Battery.
I am going to be faced with a very similar circumstance soon as I am splitting up my battery bank between the trcuk and the trailer tongue ares. Will have 300AH capacity in both location. I may want my Truck alternator setup to charge one 300AH capacity in certain disconnected events when only using my truck and I believe my alternator is a 110AMP system... Normally my PD9260C Converter/charger unit will be charging the two 300AH battery banks...
This is my changes coming up for me to do something similar with you are wanting to do...
My Deep Cycle batteries have been increased to 150AH since this drawing was made... Trojans T-1275
Maybe some bigger experts will dime in here with you thought process of your Truck Alternator Setup loading down your single battery to the 650AMPS Current draw... The most I see will be 17A to 20A when your alternator goes into its bulk charging mode state of around 14.4VDC for the ONE battery. The Truck Start battery will also be demanding the 17A-20Amps so total demand from the Alternator will be 34A to 40Amps when it is putting out 14.4VDC.
What does the Alternator do when you are cranking your starter drawing all of that possible 650 AMPS... Also your AUX battery will not even be connected to the truck start system unless your alternator is doing the bulk charging mode and is putting out at least 12.2VDC switching in the BLUE SEA SI-ACR Smart Relay combining the AUX battery to the Truck Start Battery... This means the truck engine will be running then...
Like I said over my pay grade haha...
Roy Ken
