2bzy2c
Jun 11, 2020Explorer II
I found the RV you are talking about online. It looks pretty good. The owner put in a wooden / wood look laminate flooring. The flooring in there now is not factory. The cover for the stove was also added by the owner. The factory cover is made from the same material as the counter top. Those covers broke really easily. That may be the reason for the replacement. The fridge is a upgrade from what comes standard. Nice upgrade. Aside from a needed good cleaning, that is a really nice RV.
If you buy it, you will probably need to replace the tires if they are older than 7 years old. Replace all the under hood rubber. Hoses, belts, filters etc. All is cheap and easy to replace. (except the tires).
38,705 PostsLatest Activity: Jan 22, 2025
