McGruff38
Dec 01, 2017Explorer
Looking for a used motorhome to tow 7000 lbs.
I currently have a 1990 Fleetwood Flair 26, with a Ford 460 Gas motor and 3 speed transmission. The original hitch was rated at 3500lbs, and 500 lbs tongue weight. I recently had it reinforced to support about 750lbs of tongue weight, for a trip where I was going to need to carry extra water. As it is, I have in the past towed my boat (~5000 lbs) in a pinch, which was too much by far. Now, pulling my sand rail/trailer (about 3500 lbs), Is beginning to worry me. So, Im looking for something more capable. Eventually I would like to have an enclosed trailer/sand rail/bikes, and be about ~7000 lbs as my max. I have been looking a DP between about $15k-30k and seeing 34-40 foot models from about 1998-2002 in that price range (coachmans, and Gulf Streams mostly). My questions are: should I consider another gas motor, or stick to the DP knowing that towing will take place on most trips? Tow ratings/capacity are pretty tough to find online, what should I expect to see? aside from the motor and trans, what should I be looking for to make towing more comfortable overall? Is air ride suspension in all DP, or is it an upgrade? Ive never driven an air ride vehicle, how does it compare to a vehicle on springs? Finally, is the any erra specific things that changed or were trends I might want to look for or avoid around 1998-2002?
