Looking for new batteries
djbroughton
Does anyone know of any deals on 6 volt, deep cycle AGM batteries for my coach? I will have to replace the 4 of them soon and am looking. I'm not hung up on name brands, price-point and Amp Hrs are important. I just checked at Sam's Club and they don't carry their 6 volt Duracells in stock only online. We are on the move for the winter and currently in Springfield, MO, heading southwest and probably ending up in southern Arizona.
Thanks,
Dave- Calgary, Alberta
06 Monaco Camelot 40 pdq
37 REPLIES 37
lawrosa
https://www.youtube.com/watch?v=EqCgz_Vbnag
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
lawrosa
Get a battery filling system if you can reach the back ones...
https://www.youtube.com/watch?v=xnNcku2sldE
Mike L ... N.J.
rgatijnet1
Opps, wrong link
lawrosa
4 wet cells from batts plus bulbs are 500.13.. Less $72 after core return = $428 bucks..
After 10% off and taxes....
https://www.batteriesplus.com/Checkout/Review
Mike L ... N.J.
GordonThree
Since you only use the top half of the charge that's only a 20ah difference.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
lawrosa
The only AGM i see at sams in my area anyway are 190 ah only...
https://www.samsclub.com/sams/golf-cart-batteries/3990117.cp?navAction=pop
The wet cells will get you 230 ah...
https://www.driveduracell.com/pub/media/wysiwyg/1855.pdf
So your paying a lot of $$$ for a lower ah..
https://www.driveduracell.com/pub/media/wysiwyg/1688.pdf
Mike L ... N.J.
GordonThree
Sam's Duracell are manufactured by East Penn. Google the Deka 8AGC2
djbroughton
I appreciate the many comments and suggestions but back to my original question....
1. we are travelling through the U.S. so I can buy them here on our travels.
2. I want to try AGM's because my battery tray does not slide out enough to check the back two batteries. I took the batteries out this summer, cleaned and lubricated everything but the slide still does not move enough to access all.
3. I am pretty good about maintenance but still keep boiling off the water in the rear batteries and am tired of fighting to add water and have ruined several sets of clothes with splashing acid,
4. I am willing to try the Sam's Club Duracells but can find no tech info on them anywhere. I stopped in at Sam's in Springfield yesterday and they were no help.
5. I am willing to order them online through Sam's and pick them up as we travel.
Does anyone have the tech specs on the Duracell AGM's?
Dave
2oldman
rgatijnet1 wrote:
I was concerned about them in the RV industry.
My cell phone battery can get pretty hot from time to time.
rgatijnet1
MM,
Thanks for the explanation. I had heard the Li batteries had a problem in the aviation industry so I was concerned about them in the RV industry. Thanks for clearing that up. Apparently the designation for your batteries are LFP.
Mr_Mark1
rgatijnet1 wrote:
Mr.Mark wrote:
On my current coach, I have 4 sealed AGM chassis starting batteries, it has looked new in that compartment for 3 yrs. now.
Our 3 house batteries are Lithium Ion, so, clean as a whistle in that storage bay too.
Safe travels,
MM.
Do they have a fire suppression system in your house battery bay?
Rgatijnet, there is a lot of misunderstanding about Lithium Ion batteries.... they are not all created equal.
And no, there is no fire suppression system needed in our type of Lithium Ion battery technology. We DO have a fire suppression system built-in over our engine area with a warning control panel by the cockpit.
Here is the snippet from Liberty Coach....
"The Lithium-Ion system we are now using is a Lithium Iron Phosphate battery which makes it inherently safer and very stable compared to the Lithium Cobalt Oxide which is very volatile. You may hear from some people that these are very unsafe, have been recalled, explode, etc... it is also not efficient in our application and has a much shorter cycle life, so we are not using that type of Lithium-Ion battery. The batteries that explode and experience thermal run-away when damaged or overcharged are Lithium Cobalt Oxide. We are using Lithium Iron Phosphate technology."
Our conversion company has been using this technology for over 7 yrs. with no problems. I have a battery monitoring system and the batteries never seem to get any hotter than the outside ambient temperature.
Our three LI batteries replace 10-12 regular batteries saving weight and space. Our batteries are expected to last at least 10 yrs and can be brought down to a 70% level of discharge many times with no ill effect to the battery life.
Safe travels,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
2oldman
Newer LifePo4's are safe batteries. Wet cells aren't exactly the safest batteries to be using anyway. They're just cheaper.
rgatijnet1
Safe travels,
MM.
2oldman
