gja1000's avatar
gja1000
Loose side mirror
The passenger mirror (Manual) on my Class C Ford F-350 is loose where it attaches to the arm, and vibrates out of place so it is unusable. Any idea how to tighten it?
    • I don’t have any adjustment screw that is visible. There is what looks like a plastic plate that might give access to adjustment screw. Is that what I need to do or is there somewhere else that I need to look.
  • If it is a Velvac mirror,which it should be,there is a adjustment at the end of the arm,use a screwdriver to unscrew the cap, under it you will see inside the opening a hex screw I think a 3/8. turn it to tighten the mirror head.
  • The ones I've seen have a small Allen screw on the side or bottom of the arm to adjust and tighten the mirror.
  • 2015, Coachmem, no delamination. The arm is metal and the shell that holds the mirror and attaches to the arm is all metal.
  • Gjac's avatar
    Gjac
    What year and make is your MH? Do you have some delamination around the mirror?
