Gator48's avatar
Gator48
loosing Propane
Getting ready for a trip tomorrow I checked LP and the tank was empty. Last check I had 2/3 full. The LP switch was left on from the previous trip.
I had the tank refilled and when the LP switch is on I can hear a "gas flowing" sound through the regulator, but I can't find a leak. I sprayed soapy water on every joint and connection from the tank to the stove, water heater, front and rear furnace. Nothing! No gas smell either. If I turn the switch off the noise stops.
Anybody have an idea? Could it be something with the regulator?? I tapped on it with a screwdriver handle and it made a vibrating sound, but when I turned the switch off and back on it stopped, but the "flowing" sound continued.
2006 Itasca Horizon 40FD
