Loss of 110
noleakman
I have an 06 National Sea Breeze W22 with a Xanrax Freedom 45 inverter ! I have lost all 110 power to the front and rear TVs and cable boxes! all of the other plugs have 110 and fridge and air all work! and with the inverter on the plugs have power but noon when plugged in on straight 110 with no inverter! Is there a reset button?
15 REPLIES 15
dougrainer
noleakman wrote:
also the on board charging system 110 is not charging either battery! But the batterys charge off the engine! no buttons on inverter!
Odds are the INCOMING 120 voltage from your 120 breaker panel is NOT supplying the 120 to the Inverter/Charger. There is an access plate on the inverter/charger that covers the Input and output 120 wiring. Take that plate off and use a voltmeter to verify the INCOMING 120 wires HAVE 120 volts. IF they do NOT, then backtrack to the main 120 breaker panel and verify all breakers have 120 volt output. If you do HAVE 120 volts to the input connections on the Inverter/Charger, then the circuit board for the Inverter is bad. 13 year old Inverter, I would replace instead of paying to fix. Doug
noleakman
noleakman
dougrainer
pianotuna wrote:
The "phone wires" may be for a remote control for the inverter.
He has 2 Phone type communication wires. One for the remote panel and one for the Battery temp sensor. Doug
pianotuna
Nomad III
Nomad III
Regards, Don
noleakman
All I have when I open the compartment the inverter in front of me one button that says 15 looks like amp's the management panel is on the left wall! What are the phone looking wires that are plugged in the front of the box there?
pianotuna
Nomad III
Nomad III
To test, bypass the inverter.
Regards, Don
rgatijnet1
The Xantrex 458 inverter has it's own circuit breakers. Mine were on the front on the Xantrex inverter in the basement compartment. These are not on the inverter control panel and have nothing to do with the generator or other main electrical panel. They must be physically reset by opening the compartment where the Xantrx inverter is located and manually resetting the circuit breakers.
dougrainer
1. The SUPPLY 120 line to the Inverter, breaker has tripped
2. The Inverter has an internal 120 transfer relay---It has failed, hence you have power when the Inverter is ON
3. SOME of the Freedoms have 2 breakers ON the Inverter, one or both have tripped.
4. 1,2,3 are the only possibilities. Doug
noleakman
Yes all GFIs reset!The boxs and TVs have there own circuit for invertor power and straight power from generator!
2chiefsRus
noleakman wrote:
Yes it has a control panel!and on generator the power shows fine on all plugs except the TV and Cable box are dead front and rear!
have you checked the GFI outlet to see if any are tripped.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
noleakman
rgatijnet1
On your inverter itself(not your electrical panel), you will find TWO circuit breakers. One of them has tripped.
2oldman
Perhaps your Xanrax inverter has a control panel.
