Fleet Man wrote:
Did you do a bunch of maneuvering and backing up before you shut things down. If you did, you overheated the transmission and puking fluid out the front seal is not uncommon. If your fluid is still nice and bright and does not smell burned, top it off and press on. I had a similar experience with my F-250. Scared me too but operated normally after it cooled down and was topped off. The Diesel Stop web site has many similar stories.
I would try this also rather than thinking the worst. You never know...hope it is okay.
Brian
