Sir Traveller wrote:
......... do I have to buy and add coolant even though I am not driving the RV right now ? ( its hooked up at an RV park ) Can I just add distilled water?
I will eventually add coolant before I drive it in the future of course but my question is regarding the current situation …
The OP’s question is: should I add something NOW or wait until just before I drive it.
I say if you’re not driving it, there’s no need to add anything NOW.
When you do top off any low cooling system though, always use undiluted antifreeze. Unless you’re adding a significant amount to top it off of course, then you should probably try to find out why it was so low.
