Low coolant Question
David0725
Another question about this 2 thousandand 5 Fleetwood experiod there's a little Box by the stair wheel Not sure what it goes to but it says low coolant? All the dash gages show temp is fine. Can someone tell me what the little box goes to and why it's said low coolant? I have pic but don't know how to insert them . Thank you
1994 Holiday Rambler Imperial DP
1999 Honda Accord V6 Toad
4 REPLIES 4
Ed_Manifold
My motorhome is a 2001 with the c9 Cat, about 2years ago I had to replace my overflow tank because it started leaking. The tanks are made of a plastic so they do go bad. If you are low on coolant it is probably the tank. Check-it. When coolant goes low there is almost always a leak.
Ed & Sharon
2002 Phaeton
2001 Jeep Wrangler Toad
opnspaces
Navigator II
Navigator II
It should trigger a low coolant level when it gets low but before it's low enough to cause overheating. As suggested find the radiator overflow tank and make sure it's full. I would probably also wait until the coach is cold so you don't get burned.
time2roll
Sensor is generally in the coolant recovery, overflow tank, expansion tank where the coolant gets added.
Does the fluid level in the tank seem normal?
Use this link to host the picture and provide a link to copy and paste into a reply.
http://photoposting.is-great.net/?i=3
Trackrig
Without a picture, I assume it's the little panel that gives you various warnings like low or high alternator output, low oil pressure or a low coolant level. Have you gone around back and checked the coolant level in the overflow tank. You're probably low even though you aren't overheating - yet.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
