pickerel_cove
Jan 29, 2016Explorer
I have a macerator on my Winnebago ERA. The sewer hose as mentioned is small at about 1" and there are levers to pull for gray water vs black water dumping. As mentioned above there is a button to push to run the macerator. This is all in a single running board compartment on the driver's side. They are expensive components and with the low clearance difficult to get at when there is a problem. There isn't a good way to drain gray water without the functioning pump in case it fails. Our 2010 pump failed.
38,705 PostsLatest Activity: Jan 14, 2025
