Magnetic Mount
Retired_VSP
I recently ordered and received a SIRIUS XM Onyx radio for my Baystar MH. Everything is good until I attempted to place the magnetic antenna. Since everything is rubber and fiberglass the antenna won't stick. I did barely get it to attach to a row of screws along the rubber roof. Not sure if that will hold it going down the road. That's the only metal on the roof. Has anyone had this or can suggest something to ensure the magnetic antenna doesn't go flying off?
Bobby and Lynda
Retired VSP and High School Counselor, respectively
"Try not to become a man of success, but rather try to become a man of value".....Albert Einstein
16 REPLIES 16
rgatijnet1
I found out that a few strips of Eternabond will hold my antenna with no penetrations of the roof at all. Just set the base on the roof and lay a couple of strips of Eternabond over the base. It won't go anywhere and no holes to seal.
wa8yxm
I too put my mag mounts on handy steel plates I've put up for them.
Give 'em a couple 3 coats of Rust Control before you put 'em up though.
Canadian_Rainbi
I had to think where I put ours! There is a steel frame for the TV cabinet above the front dash. Works great on that. Fibreglass is no barrier to UHF signals.
SCVJeff
Winnebago put a steel plate on the roof, stuck the antenna on it and sealed the entire thing in a pool of Dicor.
Also as mentioned, the antenna will work just fine UNDER the roof as long as there is no metal between the antenna and sky.
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
Dutch_12078
On our previous coach, I put the XM radio antenna at the back of the front overhead TV enclosure. It worked fine. On our current coach, the previous owner had added a 12"x18" sheet steel panel on the roof that currently holds the magnetic XM antenna, and two magnetic cell antennas that need the ground plane for the best signal. The PO told me he secured it with 3M double sided trim tape and sealed it with Dicor.
Dutch
2001 GBM Landau 34' Class A
chuckftboy
I have a pusher so my generator is in front an mine is mounted on the generator cabinet, works just fine.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Thunder_Mountai
I would go with silicone or dicor.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
Healeyman
Before you go fretting (and drilling holes) about where to place the Sirius magnetic antenna, check out several locations WITHIN your RV.
When Sirius says that the antenna needs a clear view of the sky, they mean at RADIO FREQUENCIES, not visible light frequencies.
The Sirius Sat Radio signal is in the 2.3 GHz range. Most computer Wi-Fi routers are in the 2.4 GHz range. That means that with NO METAL overhead obstruction, your Sat antenna will work wherever your computer or Wi-Fi will work.
For years, my Sirius Sat antenna lived under the mattress in the cab-over bed area. Now it sits in the dash just behind the windshield wipers.
Tim
Bumpyroad
Retired VSP wrote:
Bumpyroad wrote:
I thought of using silicone sealer to stick down a round electrical outlet cover but the other recommended stickum is probably a better idea. won't it work on the dash?
bumpy
I have actually laid the antenna in the left corner dash near the windshield parked in driveway and the signal is great. I'll test it out on a trip.
with my antenna on my Highlander's dash there are a couple of locations with dense woods next to the road on the SE side where it shortly blanks out and when I moved it to the roof they no longer lose signal. not a big enough problem to go to any trouble however.
bumpy
Y-Guy
Moderator
Moderator
Moved from Dinghy Towing to Class A.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
Retired_VSP
bumpy
Bobby and Lynda
j-d
I'd stick an electrical box cover to a fiberglass roof, maybe even the fiberglass A/C shroud. But I fear it'd try to lift the rubber roof into a bubble or a tear...
Bumpyroad
bumpy
Retired_VSP
Thank you all very much...very helpful info!
Bobby and Lynda
