- Old_CrowsExplorerNAPA carries Liqui-Molly 5w40 229.51 ...... USUALLY on the shelf. Also Hengist & Mann filters.
- Gonzo42ExplorerI think you really should go with whatever is spec'd in your owners manual. Personally I wouldn't trade between grades as we did 60 years ago. Oils are much better now.
- FastpaddlerExplorerIs that synthetic and, is 5w40 better for stressful hill climbing and hot weather?
- bar_20ExplorerI have the 5 cyl engine. It's a 2007 Roadtrek on a 2006 Freightliner chassis. Shell Rotella T 15-40w is a recommended oil for this engine. The 2007 and on 6 cyl. uses a different spec like you said. If you have the 5 cyl engine the Rotella T oil is ok to use.
- FastpaddlerExplorerAm I correct that everybody is using Synthetic oil for oil changes. Other question: When I go South from moderate temps here, which is better for high temperatures and lots of hilly climbing: 5w30 or 5w40 synthetic? Thanks.
AL - Gonzo42ExplorerGot my oil and filter from Amazon at reasonable cost. See thread here:
http://forums.goodsamclub.com/Index.cfm/fuseaction/thread/tid/27502705/gotomsg/27512305.cfm#27512305 - FastpaddlerExplorer
midnightsadie wrote:
bobo ,yep , and we love it.
Ours too. 2006 Pleasureway Plateau TS(with I-5) and 2007 interior build with corian,leather etc. We love ours and camp for a week or two on trips.
greetings
AL - bobojay5Explorer
gdoug83 wrote:
More information than you may want. The complete list shows all operating fluids if you are interested in doing more of your maintenance.
Just so we don't confuse the OP too much, most of the oils on the list are not available in North America. Kinda hit & miss what you can find here at reasonable prices.
Also, you can use 5w-30 in the 229.51 spec engines, but again it's very hard to find it vs the 5w-40.
Stick with Valvoline, Mobil 1 or Fuchs, and you'll be good to go - gdoug83ExplorerMore information than you may want. The complete list shows all operating fluids if you are interested in doing more of your maintenance.
About Motorhome Group
38,707 PostsLatest Activity: Feb 13, 2025
