Mercedes Dodge Sprinter Winnebago VIEW Key & Fob
pierandpatti
I need to get a second key/fob for my 2007 Mercedes Winnebago VIEW 23H. I had a key made at a local store but it doesn't work: the Mercedes/Dodge SPRINTER truck on which the 23H is built comes up with "Start Error" when I try to use the plain duplicate key. Apparently the vehicle requires the "fob" part which contains a chip which transmits a signal to the Sprinter van/truck to allow a start. Going to the Mercedes dealer I'm sure will cost big bucks. Any ideas?
7 REPLIES 7
fortytwo
The key, fob, and programming is about $450. Allegedly there is (or was)one source that can program the key alone for the pre 07 chassis. The key itself has a non-powered chip that responds to a query by the switch. You can leave the FOB anywhere in the cab and use the key alone to start the engine.
A few 07 and later Sprinters are subject to a "no-start" problem. Several threads on the View/Navion forum on that problem. All of us that had the problem have speculations, but "the" fix has never been documented. Mine was fixed with a new key and fob.
Wes
"A beach house isn't just real estate. It's a state of mind." Pole Sitter in Douglas Adams MOSTLY HARMLESS
Gonzo42
My local keysmith said he could get me the fob but it costs about $200.00. Fortunately I found my second keyset before buying.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
JaxDad
If it's the standard Mercedes key it must be programmed into the vehicles computer.
If it's the older style as used in the Dodge / Frieghtliner the key itself can be reprogrammed to duplicate an existing key.
Shame on the locksmith who cut you a key without reprogramming it for you though!!!
Bumpyroad
anything for a MB costs big bucks.
bumpy
neschultz
Search the View-Navion forums (3 including the ones for mods and tech) on Yahoo. I recall some discussion of this there. You may have to join to search or post.
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
obgraham
I believe with vehicles like this the only way is via a dealer. They will reprogram all your key fobs. Not cheap, either.
1492
Moderator
Moderator
Moved from Forum Technical Support
