pnichols wrote:
Here's my comments regarding a Class B+ or Class C RV built on a Sprinter chassis:
1. Coach walls and steps are too low to the ground - how you gonna take them reliably off paved roads?
Response: Not a problem. A rough two track, not good for any Class C.
2. Too tall for their dually track-width in the rear - they look unstable side-to-side.
3. Difficult to find emergency servicing when something goes wrong a long way from home.
Response: With modern computer operated vehicles-even a GM/Ford owner can have problems in the middle of nowhere. No question there are more GM/Ford shops. The key is a good vehicle in the first place, good maintenance, and good towing insurance. Freightliner (owned by MB) will perform service if there is not an available MB dealer. Also there are a lot of specialty shops that deal with the Sprinter. The same problem can be be said for Toyota, Honda, KIA etc. GM/Ford are more numerous.
4. They're not basement-design motorhomes - where's the several smaller outside storage cabinets that are actually tall enough to fit much into (in addition to the single main one that they all have)?
Response: We have more than enough storage, its one of the reasons we liked the Thor 25H/L.
5. I don't think that the double coach batteries are right under the doorstep - accessible from the outside or inside, rain or shine ... and kept a bit warm from being located just under the floor of the coach in cold weather. (Warm batteries perform better in the winter - which is when you need them most to perform up to their full potential.)
Response: Batteries are under the step.
6. If you want one with a stronger coach structure you must get one without slides. But without slides, they are just too narrow to get around in.
Response: This is a common issue to all RV's, I am not sure its a problem.
7. The commonly available Ford E450 and Chevy 4500 chassis under a motorhome means you can pretty much carry anything you want in them if you have one of those two chassis under a Class B+ or Class C motorhome up to around 28 feet long.
8. Diesel is available in whole lot of places but not "everywhere". Gasoline is available in just about every little podunk U.S. town.
Response: Not really a problem.
9. Not a lot of the Sprinter based rigs have a full cabover sleeper bed. You may have to search hard for a cabover bed one that also has the other features you might want.
Response: Thor, Forest River, Coachman have numerous cabover models. I am sure there are others.
10. It unfortunately may not be recommeded to idle the Sprinter engine an hour or two in order to take advantage of it's large alternator in order to quietly and quickly charge the coach battery bank in noise sensitive drycamping situations where solar won't do it and where the built-in generator may be too load. This idling limitation does not exist, for instance, with the Ford V10.
Response: I don't like idling any engine. Time on an engine is time on an engine. It takes a lot of hours even with a big alternator to properly charge a battery. When off the grid, we use solar(its worked exceptionally well, even in the sun deprived areas of eastern US in the winter)for most of our electrical needs and have an inverter when necessary. Our backup is a diesel generator. We do not use the generator to charge batteries.
11. For what it's worth speaking from experience, the Ford V10 pulling our small Class C has continued to pull strong so far up to and through a 11,300 foot pass in Colorado.
Response: Probably not a problem for a Ford V10 with a small Class C. Every NA engine including the V10 has lost at least 33% of its power, some claim up to 44%, just a fact of nature. In a heavy rig at altitude the loss will be felt.
In most respects it just a matter of what the owner likes and dislikes. We like our Thor/Sprinter.
