ezgoin
Feb 21, 2015Explorer
MH tire PSI conflicting info
The Yellow capacities sticker in my 31' MH lists cold Max PSI at 85 lbs. for all tires, but the Ford chasis sticker lists max PSI at 82 lbs., at the same load capacities. I know it's not much difference, but I was considering lowering the PSI slightly as I'm a little under max GVWR. Which numbers should I use? Any suggestions?
Thanks for all your help.
