Ever since we purchased our MH we've had issues with the hot water tank mixer valve. First year we owned ours this valve was replaced as it was noisy. In less than 3 years it needs replacing again. ...
Those that 'bypass'---'remove' mixing valve (Atwood XT Models) are you changing out t-stat to lower temp or just leaving the stock 160*F t-stat and then it's user beware (if you even tell anyone) ??
