Kidoo
Jun 03, 2022Explorer
Monaco Fuel gauge FULL all the time
Hi, I have a 2003 diesel Monaco Cayman and my fuel gauge started to indicate full all the time. Before, it indicated full only when it was warm outside, when cold it indicated the correct fuel level.
The fuel sending unit is a Centroid Capacitance type unit like they use on aircraft. I can get a new one from centroid but it is very expensive with shipping, tax and custom to Canada and I am not sure it will fix the problem.
The sending unit has 4 wires, pos. neg. send. alarm. I wonder if I can use a normal standard float 2 wires unit. I don't car if alarm does not work. A member of this group has used it and he said it works fine.
I wonder how I could wire this float unit. The float unit has a negative and positive wire only. Should I connect the pos. to the pos. wire and the send to the negative wire, or pos. to pos and neg. to neg. will it work with my RV gauge?
Thank you.
Thank you.
