MURPHY55347's avatar
MURPHY55347
More things equal more problems
We have a Winnebago Vista 35F that has a second bathroom. The black tank for this is opposite from the main black tank so it uses a macerator to pump it over to the main drain side. Went to dump so I am at the main drain and DW is stationed at the valve by the macerator.I tell her to pull the valve and I am on the other side starting the pump. She says it is leaking a little bit. I figure no big deal as it will only take 30 seconds to empty. Went over to her side to find about 3 gallons of the nasty water sitting in the storage compartment. Sopped it up the best we could. Got home and used the shop vac and bleach water to clean but it has that felt carpet in the bootom of the compartment that still smells. Any ideas on how to clean it up better and remove the smell? How easy is it to pull up the carpet? Can't see exactly where it was leaking but it is just the valve connected to a reducer that goes to the pump.Looks to be a rubber boot with clamps that may be the problem. Will investigate further this weekend but warranty visit to Forest City had already been scheduled for other isssues. Add one more to the list!!!
