MrWizard
May 30, 2023Moderator
My 1995 34ft Safari DP, had 22.5 tires at $400 per tire,
My current RV 1997 gasser Bounder Ford F53 Chassis 16" tires, $150 per tire, the the Safari ride and Bounder ride are different , not so much in the " seat of the pants feel" but in body lean braking dip, wind stability, Its Not bad, just different i have no complaints with this Ford chassis, but the tires do wear out sooner,
None are going to ride and handle like a car, the best handle like a bus, the worst like a worn out truck,
Bigger tires means the vehicle has more weight per tire on the road a heavier Chassis and a stiffer suspension, less roll & lean than the same RV house, on a smaller tire lighter chassis
38,707 PostsLatest Activity: Feb 18, 2025
