rjstractor wrote:
ron.dittmer wrote:
That is decent fuel economy. Too bad that chassis is offered only with a SRW axle. A DRW would have done the chassis wonders.
I've seen this comment regarding this chassis from you before and wonder why.
I have read a number of times on various RV forums, comments from owners of Dodge Promaster 3500 based class C motorhomes. They state that they are very limited regarding what they can carry. They are counting each pound. They can't have a 3rd passenger and never drive with fresh or waste water on-board. The basic house with all it's features, simply takes up all the weight margin.
Having dual rear wheels in back if only to gain an extra 500 pounds of capability where it is needed, would solve much. I assume the front wheel drive engine and transmission could handle the extra weight of a duel rear axle & springs plus an extra 500 pounds. If not, then I feel the chassis is even more questionable as a cut-away.
The class B application (a basic van) is all together different because it weighs significantly less than an outfitted class C. Being front wheel drive, there is no drive shaft or rear differential. The extra under-belly space provides outfitters with more area to utilize compared to a rear wheel drive Sprinter or Transit equivalent.
I am no expert on these things. This is only my opinion.
