mystery plug in Damon Astoria.
btilfan
Can anyone tell me what this is for? It's in the storage bin directly behind the passenger side wheel well. the bin also contains the cable input jack.
2007 Damon Astoria Pacifica
My next hobby.
10 REPLIES 10
4x4van
Could be a plug for a power awning?
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
btilfan
dougrainer wrote:
Here is the Manual with wiring diagrams. Doug
1. Passenger side. WHERE? Front or rear wheel well? VERY rare to have a Cable INPUT on Passenger side. Usually the passenger side has a Antenna/Cable OUTPUT for connecting a TV to watch under the awning. Especially on your year model.
2. IF the Cable plug is just a coax threaded AND NO PHONE PLUG IN, then that coax is an output. the Cable/Phone input is on the same plate. Usually either the Shore cord comp or the Water utility compartment. Doug
sorry doug, I miss spoke that is the cable outlet plug in that same bin. but it's the 6 prong plug that I can't find an answer to. does not list it anywhere in the manual.
https://recreationalvehicles.info/2007-thor-damon-astoria-owners-manual/2007-thor-damon-astoria-owne...
My next hobby.
dougrainer
btilfan
I can't find the other end of it. Damon was bought by Thor. I can't find anything on the Thor website. Hoping to find a Damon Astoria group.
My next hobby.
time2roll
navigator2346
Why don't you call the manufacturer?
wa8yxm
I will go with it has to do with an option you don't have.
Standard practice is to make one wiring harness. And then just use the wires needed for the options you have. This it seems is cheaper than makign 40-leven different harnesses depending on the options you want.
OR so they tell me.
dougrainer
newman fulltimer wrote:
Its 12 volt for a secondary heater
If so, why would it have 6 pins and not be amidships? I think the OP needs to contac Damon and find out what options were available that they do not have. Doug
newman_fulltime
Executive45
Depending on the options available for your model, that plug may simply be an extra for one of those options that your coach does not have. Wire looms are made for every available option but not all those options are put on every coach. I would check for power on each wire and if one is found to be hot, I'd cap it off so that you won't have a short somewhere.....Dennis
