Bordercollie's avatar
Bordercollie
Mystery Switch
2004 Fleetwood Tioga 26Q, Ford E-450.
There is an on/off switch located just above the power mirror control on the windshield pillar. It's not labelled, not mentioned in the Ford owner's manual. Toggling the switch does not seem to do anything. I've owned the rig since it was new, never noticed the mystery switch til now. BTW the owners manual is somewhat generic, it also covers passenger car features and a variety of entertainment systems.
This must be a common mystery switch in 2004 E-450 cabs. Can anybody solve the mystery?
  • wildtoad wrote:
    Just a guess, but sounds from your description like a switch to turn on and off the heating element in the mirrors.
    This. At a guess, it is a pair of rectangular Velvac mirrors-very common on cutaway Fords of that era. I drove a couple of shuttle buses with the same setup-and yes, the switch is for mirror heat.
  • Our 2003 had the same switch for heated mirrors. Don’t want it on by accident. My grandkids love switches! I sure miss power windows on our newer RV!
  • Bordercollie wrote:
    Thanks, that's probably a heated mirror switch will check it.
    Gary, if you first look into that mirror then flip the switch ‘on’ , if you see your reflection appear younger then its a booster switch. An Ego Booster Switch, they are referred to as a EBS.
    I use mine all the time. :). Even if its just a heater switch, its fun to play pretend.
  • I agree, it is most likely to switch on the heat for the rearview mirrors.
    It isn't mentioned in the Ford manual because the mirrors (and their controls) are not Ford products, but e.g. Velvac or other aftermarket mirrors. The stock Ford mirrors generally aren't used because they don't extend far enough out from the cab for good visibility alongside an RV body, I assume.
  • If it's not a Ford looking switch then maybe it's your battery switch over, so that the coach can power the vehicle to jumpstart it.
  • wiltoad, that heated mirror switch may be the answer. The mirror control has it's own switch. I'll try it and see if I feel warmth. We don't get much frost here in SoCal.
    Thanks!
  • Just a guess, but sounds from your description like a switch to turn on and off the heating element in the mirrors.
