David99
Apr 28, 2018Explorer
Yes thanks Eric, I have just talked to them. I am a little skeptical in that they want to build a new radiator from scratch, for about $1200 but I may go with them after I compare them to Fleet Services. I took it to Fleet and they can do the job. I guess I just needed to go to a heavy duty truck repair facility. Fairway said the stock replacement all aluminum radiator does not have enough capacity but the original one worked fine pulling my towed Ranger pickup up the grapevine. (I no longer have a toad so it's unlikely I will overheat.) I also pulled the toad in Arizona about 8 years ago when the fuel pump went out, but the temp gauge stayed in the middle all that time with the outside temp at about 118 degrees.
I am now much more comfortable with either Fleet Service or Fairway, neither of which said it would take 24 hours labor to R&R the radiator.
Thanks for all the leads!
Dave
Dave
38,705 PostsLatest Activity: Jan 22, 2025
