JumboJet's avatar
JumboJet
Need Help - 1999 Ford F53 V-10 Wiring
I have a dilemma that I a trying to overcome. I went online and paid an ASE Ford mechanic for help. I did get general help but nothing I did not already know after research.
The first picture shows the IAT (Incoming Air Temperature) sensor wire that heads to the PCM chewed into by mice. The gray wire goes to pin #39 and the gray/red stripe wire goes to pin #91 (shared with other sensors). On some 2000 and later, the IAT is integrated with the MAF sensor.
The second picture shows the hole that goes through the flap attached below the firewall. The IAT wire goes somewhere into the engine compartment. Anyone on board know exactly where?
I did find the Cylinder Head Temperature sensor wire chewed into and was able to trace it and repair it.
  • n7bsn wrote:
    Don't know, but I have the Chiltons on the 99 F53 chassis (also all other F series 97 to 2000) that is currently sitting in the Good-Will donation box
    I'd send it for the cost of shipping.
    I will email you a FedEx label tomorrow if you care to PM me your email.
  • Don't know, but I have the Chiltons on the 99 F53 chassis (also all other F series 97 to 2000) that is currently sitting in the Good-Will donation box
