Need help locating a part.
Hsthompson71
I have a 2008 holiday rambler augusta on a chevy chassis, What I believe is the rear anti sway bar was held up by 2 brackets, unfortunately those 2 brackets broke off on the highway. Was just hoping someone here might be able to Point me to a website or store where I could get them. Please and thank you in advance.
11 REPLIES 11
bobndot
MDKMDK wrote:
If it's on a Chevy chassis, wouldn't it make sense to try a Chevy dealer? Preferably one that services the 4500 cab chassis, if that's what it's on?
You had the answer 5 mins after you asked your question. 🙂
Glad to hear its resolved.
Hsthompson71
Thank you everyone I didn't even think to call chevy ?? got the part and I'm back on the road!
klutchdust
enblethen wrote:
I believe the OP is talking the rear factory sway bar.
Whatever sway bar, my point was beware when ordering because the original and aftermarket are different size. IF there is no markings/tags on it how would one know?
AND how do they break? right at the bend. The bolt holds the tab to the frame and the bracket breaks where it is bent. The bar twists the remaining piece until the sway bar falls down. That's what mine did but in the front.
bobndot
If its the OEM factory sway bar shouldn't Chev have the part ?
IAMICHABOD
If that is so then the rear brackets would be These Brackets that attach to the rearend housing,I really don't see how they could fall off.
If he is talking about the Rear sway bar end link this would be it. Both hold the rear sway bar up,I can see how this may break.
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
klutchdust
My experience has been that if it is a roadmaster sway bar you need a roadmaster bushing. Even then be sure it is sold by roadmaster. I purchased
bushings/brackets for my front end on my class C Ford and they did not fit. Aftermarket import copycats are slightly off. Once i measured my bar
using a micrometer did I see the difference in size. I ordered what I believed and what was advertised as original equipment bushings for the front
end of my GMC 2500 and they were not the same. E trailer is a good source, very helpful with all my purchases.
bobndot
Look up Hellwig and Roadmaster rear sway bars , 4500 chevy See if either of those bars match what you have.
A1B00902
I think you are talking about the SWAY BAR LINKS, at any auto store,
and not to hard to place yourself,
check on YOU TUBE on how to replace them yourself
enblethen
Make sure you measure the sway bar diameter. These are also the same as Unistrut clamps. Need sample to go to electrical supply house.
O'Reilly Auto parts
Bud
USAF Retired
Pace Arrow
MDKMDK
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
