campingman55's avatar
campingman55
need help with led
i need help trying to find a led the number of the bulb i want to replace is WB36X10213 i have try to find it but i cant i know u guys are the best at finding it for me thx for all the help it is for the light under my ge profile 120 conv oven it is a advant 120 model number is sca1001 hsg 02
  • Your halogen bulb uses 20 watts at 120 volts. It is a G8 base. Hero LED Stores.com has the equivalent. Part # LB-G8-COB7.5W-UNV. It is not a good idea to bend the contact leads, as it may crack the glass.
  • Ivylog's avatar
    Ivylog
    The pins on a G4 LED may be closer together than what you have, but they can be bent apart if necessary. Here is what I found on Ebay.
  • that number comes up as a halogen bulb which you can pick up at Lowes or any home center.
    http://www.appliancepartspros.com/search.aspx?model=sca1001
About Motorhome Group
38,705 PostsLatest Activity: Jan 24, 2025
Related Content
