- fijidadExplorer
time2roll wrote:
Have the dealer show you how the fridge is connected when you pick it up.
This was a helpful tip. When I picked up the rig, I asked how the refrigerator and ice maker were plugged in. He showed me the outside removable vent cover for the refrigerator on the passenger side, and behind it, the two were plugged into different outlets. I said we don't do dry camping, so are not concerned about the refrigerator draining the batteries through the inverter. He said I could simply unplug both and swap their locations and I'd have the refrigerator plugged into the inverter. When I got it home, I did that. Took me 5 minutes. And that's because I work slow. So, thanks again for this suggestion. - Have the dealer show you how the fridge is connected when you pick it up.
- fijidadExplorer
Bruce Brown wrote:
While I'd agree with the thought behind that it sure would be easy to take a look and find out.
I'm intrigued. "Easy" is a word about which reasonable men may differ. This refrigerator/freezer is recessed into a cubby and, at least at first glance, looks like it would need to be pulled out to see how and what is plugged in. Do you have information that may help me find the "easy" solution? - Bruce_BrownModeratorWhile I'd agree with the thought behind that it sure would be easy to take a look and find out.
- fijidadExplorer
time2roll wrote:
fijidad wrote:
ArchHoagland wrote:
When you say refrigerator...is that a typical RV refrigerator with gas or electric option or is it a residential refrigerator?
What brand/model refrigerator?
I just heard back from San Diego RV, and they said the inverter only powers the ice maker, not the refrigerator; and that the refrigerator needs to run on propane.
Now, we can do that, but the refrigerator works fine when we're plugged into the RV Park pedestal...and the propane is off.
So why wouldn't it work off the inverter?
probably not connected to inverter power.
The ice maker is an integral part of and located inside one of the two freezer compartments. Hard to imagine it has a separate power cord. fijidad wrote:
So why wouldn't it work off the inverter?- grldstExplorerBeen RVing for 30 plus Yrs. Boondock 2-3 months a yr. have had 4 different motor homes with Xantrex inverters and have never had a problem with them. There is a guy in Metro Phoenix area that sells refurbished xantrex. Guarantee them and reasonable price. Should pop up with a google search.
- fijidadExplorer
So why wouldn't it work off the inverter? - MrWizardModeratorRunning/powering and RV fridge from the inverter is a waste of battery power, 300+ watts for the heating elements uses 30 to 40 amps D.C. Battery power into the inverter to get the 3 amps 120vac for the fridge heating elements,
The best thing is to use propane for the fridge when not connected to shore power, this RV has an RV gas electric fridge, I power it exclusively from LP unless I run out of propane, in which case I switch to electric and inverter while I drive to the LP station,
For 7 years with a previous RV I did power a residential fridge from inverter, with 649watts of solar pane on the roof and 500+ AmpHrs of battery bank, that fridge compressor only need 100 watts of electric power
RV gas electric absorption fridge need 3 to 4 times as much electric power,
I use l.p. And keep electric as emergency backup operation
With this fridge - Sandia_ManExplorer IIFirst, our Xantrex 2K watt inverter charger has performed flawlessly whether providing 120Vac to our coach or charging our 4 golfcart batteries. Second, we have the larger 4 door Norcold in our rig and inverter is not wired from the factory to power our fridge. I asked the previous owner and they stated the factory told them no need as propane mode is commonly used when off the power grid.
On my last rig I installed a dedicated inverter for our RV fridge thinking I would save on propane and not have to have it in gas mode while traveling. Neither assumption were truly vindicated, we found batteries down upon arrival, not good when you are boondocking. Our RV fridges have always performed well across many rigs, they stay cold for hours, we use propane mode as needed while traveling.
About Motorhome Group
38,764 PostsLatest Activity: Dec 23, 2025
