falconbrother
Dec 14, 2014Explorer II
Need some help old air bags/springs issue
I got the airbag out of the right side in a couple of minutes, it was quite dry rotted. Not much to it. On the left side there was no bag in there. As looked up in the hole I discovered a plastic or hard rubber ring around the bottom of the spring. It will not come out with a little prying and pulling. That sucker is in there and feels like its partially under the spring. Also, it looks like the spring still has a little black paint on it. Is there such a thing as a plastic buffer or something that rides under a spring or is this part of the old air bag that has worked it's self under the spring? Also, I looked up into the spring and noticed that there doesn't appear to be enough room to put the ring shaped tops and bottoms for the air bags in there. Is that a critical part? I was well on my way to getting this job knocked out now, it will be tomorrow at best. Not till after the Christmas trip is probably what we're looking at.
