dmopar74's avatar
dmopar74
Need tires for 98 rexhall aerbus
I'm picking up a 36' 1998 rexhall aerbus tommorow and will need to be tire shopping soon. Stock tires are 235/85/16 load e. What are some good tires for this big bird?
  • Deano56 wrote:
    no need to be high end name conscience, plenty of bad reviews on them too. I second Hankooks, you will most likely age them out before you wear them out anyway.
    X3
  • no need to be high end name conscience, plenty of bad reviews on them too. I second Hankooks, you will most likely age them out before you wear them out anyway.
  • It came from the Ford factory with Michelin xps rib's and for good reason..... The xps is an all steel tire with steel reinforced sidewalls.... Simply put... It's the best tire for that chassis....
    I buy 6 new ones every 7 years and they are not cheap!
  • Toyos from Les Schwab first choice.
    Have them get them from warehouse with newer dates. Most stores will verify date before they ship them.
  • Join FMCA (Family Motor Coach Association) Great organization with many benefits, least of all discounts at RV parks. Also, there is the FMCA/Michelin Tire Program. You save lots of money on tires for your RV and they are mounted by professionals, nationwide. Any problems, you are not far from help.
  • I prefer tires from a known national retailer in case of problems on the road. My first stop is always Les Schwab. They are usually everywhere I go.
