smarking's avatar
smarking
Neutral safety switch relay
Where is the neutral safety switch relay located on my RV?
2006 Fleetwood Providence.
Edited post follows.
Spartan chassis
Cat C-7
Allison trans.
Thanks for your help.
Steve
  • Thank you hooligan for your reply. I should be more specific in my post.
    When I turn on the Power Gear leveling system, the lights flash in a pattern that indicates that the trans in not in neutral (diesel) the system will not activate. Also I may have to turn the key several times before the starter will engage & start the engine. I was wondering if there may be a common reason for the two to not work & I was told to check the 'neutral safety switch'. It might be called something else. But I don't know where this switch/relay is located. Or else these are 2 separate problems that happened at the same time???
  • If you are looking for the "Neutral Start Back up" Switch (NSBU Switch) it is located on the passenger side of the Allison transmission.
    -Passenger side of a rear engine diesel, driver side in p/u truck.
