cj7365
Jun 12, 2015Explorer
Jrork wrote:
Here's the last update. Once we removed the pump we found the rubber hose from the actual pump to the sending unit housing was in horrible shape and was deteriorating. The bottom of the tank had all sorts of pieces of rubber from it and what was left of the generator pick up too. It too was falling about in my hand. Swapped out the pump and shazaam, it fired right off and holds pressure versus how it use to be where the pressure would bleed off almost instantly after you turned the key off. Thanks again everyone
Did you end of just replacing the pump or the whole fuel pump assembly, what part did you use?? where did you get it?
38,705 PostsLatest Activity: Jan 14, 2025
