aw2055989's avatar
aw2055989
No Rear AC or GFCI on Generator
2009 Coachmen Mirada 310DS. As of 2 days ago, i have no Rear AC or GFCI circuit (bathroom / kitchen) on generator power. They work fine on shore power. Has anybody ever had this situation? Breakers / fuses all look fine. The same circuit is used for both types of power so i don't understand how this can happen.
  • Yep, that was it. One of the breakers on the generator had tripped. So as promised...:o Ha! Thanks for the help. Since the generator provides power to the same circuit that shore power provides it too, was it just a matter of not enough current being provided by the generator since a breaker was tripped?
  • Oh boy, now that you mention that, i do recall that there are 2 breakers on the generator. So you are right, one is probably for that circuit and is tripped. I'll check that tonight and reply back tomorrow with a :o!
  • Yup, turn the ON GENERATOR breakers OFF and back ON. Sometimes they can appear to be on, but are tripped.
    Next most likely is to check connections from generator to coach wiring and then coach wiring to ATS(Automatic Transfer Switch).
  • Are you sure you checked the circuit breakers on the actual generator itself?
