thelix's avatar
thelix
No Water to Bathroom Sinks
Howdy,
I have a 2006 Pace Arrow 36D that has been parked for an extended time. In the process of getting back on the road I discovered that I have water to the kitchen sink, toilets and shower, but no water to either of the bathroom sinks. I've tried both with the pump and hooked up to city water.
Anyone have any suggestions? Could just those lines have gotten plugged somehow?
  • Thanks for the update. So often folks ask for answers but never come back and reply with the actual resolution.
  • SOLVED! Finally had some time to work on the bathroom faucets. First I took the cartridges out and cleaned them, finding nothing wrong. Then the light bulb came on and I turned the pump on with one cartridge out and water was flowing fine. Since I knew there was water to the valves, I pulled the spout/cover off and found the little feed hole to the spout from the valves was plugged solid. I knocked off the calcium deposit and success... Lesson learned. Thanks to all who responded to my post.
  • Gary, was the Pace Arrow a Fleetwood product that year? I believe it is, so contact Fleetwood and see if you can get prints for both the water system, fresh and waste, electrical and possibly entertainment systems. I don't have the number, but a search on line for it. This information is free, or it use to be anyway. Good luck
  • Thanks for the responses...
    There is no cold or hot to either bathroom sink. My first thought was the aerators but turns out that is not the problem. I get a slight trickle from the front bathroom, but thats it.
    I'm confused.
  • garyemunson wrote:
    How about the aerator on the faucets? Plugged up?
    That would be the first thing I would check. Just screw them off and check for debris in the screens.
    If that does not fix the problem I would check for shut off valves that may have been forgotten
  • thelix wrote:
    Howdy,
    U have no hot or cold to either sink??
