Norcold RV and Marine refrigerator?
royl
Anyone have any experience with the Norcold 12 volt/120 volt refrigerators made for RVs, boats and trucks. Sounds like a good solution to replace the fire bomb no cooling Norcold RV refrigerators. I am looking at the Norcold 7 to replace my 16 year old Norcold model 9652. It has a compressor and cooling coil on the rear of the unit and comes with a condenser cooling fan installed. It would eliminate the need for an inverter to power it while on the road. The cost is about the same as a replacement gas, electric model. I have only found one residential refrigerator that will fit my space and it will take 2 to 4 weeks to get it.
Roy & Sabine
2000 Coachman Classic 27 RK Fifthwheel
1992 Dodge D250
4 REPLIES 4
MrWizard
Moderator
Moderator
It's residential apt size
Rules on 120v, it's connected to a triplite inverter
I can explain it to you.
1997 F53 Bounder 36s
royl
Does the Avanti run on 12 volts too or just 120? I don't boondock but I thought the 12 volts would be good when traveling during the day.
Roy & Sabine
1992 Dodge D250
MrWizard
Moderator
Moderator
are you looking at this one
in stock ships today $1369
an Avanti 7.5 CuFt apartment fridge should fit in the same spot
thats what i installed here, when our old Norcold blew up 4yrs ago
we have been running that Avanti residential since August 2010
the inside door shelfing on ours, is different, guess they made some changes in the last 4 years
ordered it at the local appliance dealer, it arrived in three days
Golden_HVAC
It sounds like it will consume a lot of electricity, and dry camping might become a problem.
SunElec.com sells some 12 volt solar panels near $1 per rated watt. You probably have to call them, as only the larger high voltage panels designed for house mounting are shown on their website.
Look for something in the 100 - 175 watt range. Anything larger becomes difficult to handle while mounting to the roof, and difficult to walk past it while doing rooftop maintenance.
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
