Sfla2 wrote:
smkettner wrote:
The only Ford book I see says 7500 miles for an E450. 5000 if towing. Do you have a link for 3000 mile recommended change?
ok mine is a 98 in the service guide it says towing or heavy loads every 3k & we are heavy most of all bigger "c" are close to max. I can send u the page if u want. Also mine says 5 k normal 3 k heavy, could be what they said back then
Both are correct. The intervals were extended by Ford a long time back (maybe 2003?) and you can use the new intervals for all V10s. None of the internals changed, they simply found through testing that the longer intervals were safe for the motor.
I usually go 7500-12,000 between oil changes, longer when towing actually, because its the short trips that are the hardest on your oil (assuming full synthetic.... I stick to 5k on the Motorcraft blend).
But annual oil changes are good, due to condensation. Might not be necessary if its stored in a climate controlled shop, but I believe Ford spec states annual, and while its under warranty its smart to stick to spec.
