Oil Change Viscosity Mistake
Dollo
I just spaced at the parts store. In the stack of 5w-30 oil there was one box of SAE 30, and without noticing, I bought it. I did not realize it until after I had already poured the required 6 quarts back into the engine.
2005 Itasca with a workhorse chassis, 8.1 engine. In Southern Cal and will be traveling through AZ, NV and Utah.
Should I just drain it and replace it or will I be OK?
Thank you for the help.
25 REPLIES 25
stubblejumper
Oops sorry..:S
Lets see how can we communicate ?
Phone.. no they listen:h
Mail.. no they read it:h
In person.. no they bug us:h
Email... no they read it:h
Oh the hell with it when we are all in jail together we will work out something :B
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us.
Passin_Thru
NO!NO!NO! Don't Google! The Govt is tracking you! LOL
stubblejumper
With multi viscosity oils they are at the lower viscosity when starting (or cold) but once your engine has reached operating temperature they run at the higher viscosity. The 30 oil will not cause any damage in the California climate.
If you don't believe it... google "multi viscosity oil"
Passin_Thru
As per an Aviation Mechanic (me) leave it in. It will be fine as frogs hair. You won't notice any change and like jhilley says multi is for col-hot temps and won't make a bit of difference in the summer.
Empty_Nest__Soo
GMT830 wrote:
. . . Is the 30 weight non-detergent? If so, get it out ASAP.
I agree. In this day, however, I think the odds are it was high detergent, just like the multi-vis oils.
If it is HD SAE 30, I believe you're fine for warm weather.
I've always been more concerned about mixing brands of oil, each with maybe different additive packages, than with mixing viscosity.
Wayne
Wayne & Michelle
1997 Safari Sahara 3540
GMT830
I wouldn't consider running anything other than full synthetic in that engine.
Lena - 02 Yukon XL Denali
TT - Wilderness 29L
mc_cc
I mix the viscosities all the time in my 1996 suburban. I have over 200,000 miles on it. In fact, I just recently put a quart of 20w50 synthetic in with 4 quarts of 10w30 non-synthetic. Never had any engine problems. It runs like a sewing machine. I am pretty sure you should have peace of mind knowing your engine is sufficiently lubricated.
Mark
sailor_lou
mike brez wrote:
lanerd wrote:
I think his concern is not if 30w is bad for his motor, but that he "mixed" the 1 quart of 30w with 5qts of multi-viscosity oil.
I'm not sure if it will do any harm, but I've always been told to not mix different weights.
If it were me, I'd just drain and refill. $25 and your piece of mind is at ease.
Ron
The way I read it he purchased a case of sae30 instead of a case of 10w-30. Poured in six quarts of sae30 then realized the mistake.
I read it the same way as Mike, but either way I don't see it as a problem.
Lou
05 Travel Supreme Envoy
lanerd
You know, I think you're right. Darn, I completely misread it. Sorry.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
mike_brez
Ron
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
lanerd
Ron
Ron & Sandie
TPMS: Pressure Pro
Born_To_Travel
5W30 oil is actually 5 weight oil with an additive package. these additives are long strands of polymers that are like spaghetti.. As the oil warms, these long strands expand and make the oil thicker.. When your oil reaches operating temp you have 30 weight.. However as the miles add up and the oil circulates over and over, The long strands get sheared by the oil pump, making them shorter and shorter and lowering the oil viscosity.. Straight weight oil does not have this problem as it does not have the Multi-vis additive package.. 30 weight is the weight of the base oil, not 5 weight.. Therefore it does not have the shear problem and does not lose viscosity.. Years ago when I worked for a motor coach company we used straight 40 in all of our over the road diesel buses. We ran 15,000 miles between oil changes and had no problems.. It will break down eventually but you can run a lot farther between oil changes on straight viscosity oil..
Dollo
Excellent input and guidance, thank you all. I change the oil often and will likely change twice before the weather turns cold so I will be sure to use 5-30 then. More than anything the understanding of oil viscosity I have gained is worth the concern of the mistake. Thank you everyone, happy trails.
Tom_N
Quoting Workhorse's 2006 Gas Chassis Maintenance Guide below (note: the straight SAE 30 comment). Your good as long as it was HD 30W.
"VISCOSITY"
"Engine oil viscosity (thickness) has an effect on fuel economy. Lower viscosity oils can provide better economy; however higher temperature weather conditions require higher viscosity engine oils for satisfactory lubrication. Using any oil viscosity other than those recommended could cause engine damage.
Gasoline Engines – For all temperature ranges the preferred oil for your engine is SAE 5W-30. However, you can use SAE 10W-30 if temperatures stay above 0 degrees F (18 degrees C). For heavy-duty driving in summer temperatures, above 40 degrees F (4 Degrees C), there can be an advantage to a single-viscosity straight SAE 30. Refer to adjacent chart.
Note: SAE 10W-40 has been removed from all Workhorse recommendations."
Sarver, PA/Crystal River, FL/Shelocta, PA · W3TLN · FMCA 335149 · Mystic Knights of the Sea
2005 Suncruiser 38R · W24 chassis, no chassis mods needed · 2013 Honda Accord EX-L · 2008 Honda Odyssey EX-L
