I have a small oil drip at the left rear corner under the radiator area . The drip looks like auto trans oil and all I can see when I look under is where the leak has run down on what I think is the l...
I, too would suspect it's a transmission cooler..there should be two fittings, one on each side of the lower portion of the radiator. If you can get in there, make sure those fitting are tight......Dennis
