Dmeyer07's avatar
Dmeyer07
Older Class A Electrical
Hi.
I have a new to me 2000 Damon Intruder 341 Class A Motorhome that has a 50 amp setup.
50 Amp shore power plug in
7000 watt onan on board generator
(Adding 2000W 110 inverter)
And a "TODD" Automatic transfer switch (pictures attached)
I've got a couple of questions:
1. *Ignore, refer to reply below*
2. Why does this ATS refer to itself as a 120/240 ATS- is it because there is 2 hot 110 leads and 1 neutral? Technically 240 but is anything actually running 240 or putting out 240 (generator?).
3. I'm installing an inverter. Can I just install an ATS where the generator leads connect to the stock ATS, and have the inverter and generator come into my add on ATS, then go out to the generator input on the stock ATS?
I am not a complete noobie when it comes to electrical, I've been in the maintenance field for over 20 years, so please don't say hire an electrician. I just want to clarify a few things first because I'm not up on the older RV's with 50 amp service. Perhaps they did things a bit differently 23 years ago!
Thanks for the help
Picture 1
Picture 2
Picture 3
Picture 4
