turbojimmy's avatar
turbojimmy
On-demand water pump?
I'm preparing for my first trip in my newly-resurrected Allegro. It had been sitting for a very long time so I replaced the moldy freshwater tank fill tubes and sanitized the system. I noticed that with all faucets turned on at once, water slows to a trickle. I guess that's okay, because when do you have them all on at the same time for an extended period of time anyway? But, I also noticed that with just the shower on, the pump will eventually fall behind so that there's not enough pressure to feed the shower head. If I shut it off and let it build back up, it's okay again for a few seconds and drops off. Ditto at the other faucets.
I also noticed that as pressure drops off, it sputters like it's getting air from somewhere. I don't have any leaks that I can find where air would be introduced to the system.
So....are these symptoms of a weak/dying pump? They're cheap enough to replace, but I don't want to swap it out and find that I have the same problem.
