Rick_Jay
Jul 29, 2023Explorer II
dalefuji wrote:
I took fuel line from fuel pump and stuck it in gas can and no luck...
This could just be semantics, but to be clear, you need to disconnect the fuel line going TO the fuel pump, not from. That is, the fuel line coming from the gas tank. That's probably what you did, but just want to make it clear. To do this, you'll probably need an additional length of fuel line to drop down from the pump to the gas can.
I still think your symptoms still sound like fuel starvation.
Can you repeat your test where you primed the engine and then tried to start it? If that works, it's most likely a fuel problem.
When you go to start it, does it "pop" or show any signs of trying to start? Have you tried spraying any "quick start" spray into the carb to see if that would get it to "pop"?
~Rick
38,766 PostsLatest Activity: Jan 10, 2026
