mrbishop
Jul 23, 2017Explorer
Onan Generator troubles
Hi all,
I have an Onan microquiet 4000 generator. It seems to be going through brushes over the last few years. Only 1 brush wears out. I replace them and everything works fine for awhile. This last time, I noticed the slip ring on the one that wears out was worn so I thought I would replace it. I also replaced the rotor since I found some posts that say it goes bad.
After the replacement, the generator started and ran. I shut it off and changed the oil. I restarted it and was letting it run while I cleaned up tools and such. It stopped after 10 minues. I tried it restart it got a code 32, low cranking speed. I took it back apart to see if anything went wrong. I didn't see anything, checked the rotor and stator. Both checked out fine. I ordered a new board, same issue. I read something about checking brush alignment using PSB-682a. I can't find this procedure. Anyone have it? Or ideas on why my generator starts and stalls with code 32?
