Class_A_DP_1's avatar
Class_A_DP_1
Onan Marquee Generator wont crank with plugs installed?
Hi, The starter on my Generator will crank and spin the engine freely with the plugs out. When I install the plugs it has good compression but will only spin the motor a 1/2 revolution or so then stop. It sounds like the starter cannot overcome the engines compression. If I repeatedly bump the starter the engine will hiss a bit as compression releases and then turn about another 1/3 revolution and stop the same way again.
I have replaced the starter, starter solenoid, and the battery. As a test, I have connected good 12v (with good amperage) to both the starter terminal right on the starter and also to the starter terminal side of the starter solenoid (hard to get to). Both of these tests resulted in no change at all.
Is there supposed to be a compression release of some sort on these engines? Cant figure this out. ANY help is appreciated and thanks very much.
